Results 1 to 29 of 29
    Need recommendations for "bedroom" tube amp
    Would appreciate any recommendations for a tube amp that can be played at "bedroom" levels.
    SloopG
    Les Paul Forum Member 55 Jr.'s Avatar
    Edmonton Alberta
    A Fender Superchamp.
    Those things are a hoot around the house.
    High gain tones are a little buzzy, but not too bad.
    The clean tone is ok.
    I really liked the mild OD tone on it, very cool.
    The reverb is nice, but only has two settings. Light and mine shaft.
    I had zero luck trying to gig with one.
    Regards,
    Brian
    The RiverCity Guitar
    *High End Backline Rental*
    Les Paul Forum Member BostonPops's Avatar
    New England
    ZVex Nano Head. 100-mW of raging power.
    Seriously, it's a nice sounding amp.
    www.zvexamps.com
    Peavey Classic 30 is nice for around the house playing, not too big. It has reverb and channel switching as well. They aren't too expensive, either. A friend of mine even gigs with them, so they have enough power for that, too
    Les Paul Forum Member Rev.WillieVK's Avatar
    Wherever I go, there I yam.
    I've got both SuperChamps and a Crate V1512.
    IMO The SuperChamp is great but needs to be plugged into a nice 12" speaker to sound better (it has a 10"). The reverb is powered by the lead channel tube and therefore you get almost no reverb when using the lead channel.
    The Crate does mild to wild very well for a $400 amp. It has killer classic rock tones (think AC/DC and more). You can add any amount of reverb to any gain level you want. Some people have upgraded the speaker in theirs but I'm happy with the 12" it comes with. Is it a Bogner, Matchless, or Blockhead? No! But is a pretty great inexpensive, small-wattage, classic rock tube amp.
    Do a search for Crate V1512 and you should come up with more info.
    Les Paul Forum Member Don L's Avatar
    MD
    Gibson GA-5.
    Some things just have to be believed to be seen.
    Les Paul Forum Member Gannet's Avatar
    Sarasota, Florida USA
    Your favorite tube amp, any size...
    with a good attenuator.
    All Access/Backstage Pass Buffaloe's Avatar
    Searching for Elvis in Melmfus
    Either the Peavey Classic 30 or any of the Crate VC series. I have a VC20R that's just a little screamer. If I'm feeling lazy and don't want to haul the Two Rock I'll take the Crate to rehearsal and it'll keep up pretty well.
    Ham Fisted Bloozer
    The worst I ever had was just fine, thank you.
    If you have chance,check THD Univalve. It`s got attenuator built in and also you can change tubes without rebiasing it. And the sound is really good.
    Les Paul Forum Member Goldtop Dude's Avatar
    Tijuana Mexico USA
    Fender blues JR. or Pro JR. if no veb is needed.
    Founder, Creator, and Overlord of Teh Unofficial Patent Applied For Les Paul Forum Pick.
    - Dude
    Les Paul Forum Member Scott64's Avatar
    NB, Canada.
    Re: Need recommendations for "bedroom" tube amp
    SloopG
    I use a marshall jcm800 50watt halfstack in my room. works great :dude
    -Scott
    Formerly WillC
    Surrounded by trees....
    The Smicz TAD tube adaptors will bring you down to 2-3 watts and run about $100, not a bad idea.
    Replacing the stock speaker in the Super Champ with the Electro Voice 10' sounds great.
    Will
    Emery Superbaby, 8 watts , Emery Microbay, 2 watts;
    Allen Class Act, 10 watts;
    ADA Rocket 10 ,10 watts; ( Superb amp you can only get them used, because the company went out of business )
    Carr Mercury , 8 watts;
    These are all very good amps for recording and home use.
    Les Paul Forum Member 2001standardplus's Avatar
    May 2002
    Phoenix, AZ
    i use a sf champ. it sounds good to me. for a little extra i put a clean boost in front of it.
    sf champ
    7 41468
    Les Paul Forum Member GuitarG's Avatar
    Foley, AL
    I use a Blackface VibroChamp with a Jensen reissue speaker and use a box in front for some more overdrive if needed. Sounds great for a low volume practice/ recording rig.
    SUPPORT LIVE MUSIC
    Les Paul Forum Member 2002les's Avatar
    Bad Cat Hot Cat - with or without an attenuator
    Ditto the Crate V15... Cheap, Class A, Clean to Hyper, Cheap, Low Volume to Kill Elephants. Good little studio amp too.
    The THD Univalve is killer too, but not inexpensive and you'll need a cab.
    Reverend Hellhound 40/60 Combo. It's a 1x12 that can get very freaking loud, but also sounds very good at low volumes. Also plenty o' power for gigging at even the 40 watt setting. One of my favorite amps.
    Crate Vintage Club sounds great, but I have a love/hate relationship w/ mine. Sound=awesome reliability=horrible
    if you're looking for something economical, crate vc508 and vintage 5 watters (silvertone, gibson, etc) can be had for $200 or less. i have a blues jr. and pro jr. and those are both too big for bedroom use in my opinion - you can't get the volume up enough to get a good sound without offending the next room.....but my silvertone 10xl is perfect....
    Edmonton Alberta
    My current round the house amp is a Tophat Portly Cadet.
    Be warned that this thing must be cranked to give up the goods, and cranked = LOUD.
    Still looking at getting a Weber C125 for it. This should make it louder.
    And a Mini MASS so I can play it around the house.
    A cranked Portly with a FDII in comp cut mode in front is yielding some great tones but I say again, she's loud.
    Regards,
    Brian
    Thanks for all the feedback.
    Checked out some Fenders but finally decided on the Crate V1512. Small size, 15 watts, sounds very good at low volume, decent reverb. Not much in the feature category... no headphone jack, footswitch jack etc... just a nice, simple class A amp. Uses 2 EL84 Groove Tubes. Price at GC was better than discount web sites even with tax. Will give it a good workout this weekend.
    SloopG
    Found one review on amplifiers , here is the link. 30 watts Marshall amp seemed to be the most attractive. Check this and the other amps out. Maybe you'll find the one you like.
    Les Paul Forum Member Triplet's Avatar
    Mar 2006
    Virginia
    I have a couple Music Master Bass amps. Great fun to mod, too.
    https://www.tdpri.com/threads/music-...-mafia.184799/
    'then she made me play games I didn't wanna play...'
    Fer fux sake! Duane's left and Dickey's right!
    Les Paul Forum Member herb's Avatar
    Washington State
    Carr Rambler. I know, a little pricey but you can find them used for $1K or more less than new retail price, which I did. At either 14 or 28 watts it's the only amp you'll probably ever need for bedroom, recording or live use. Uses 6L6 glass. Great amp.
    Guys this thread is 17 years old and the OP has not posted on the forum since 2004 so I very much doubt if he is still looking for recommendations!
    The user who restarted the thread in post #22 is a newly registered user who has 3 posts and all of those posts have been to old threads that have had no activity for over 15 years. I'm guessing it is either a bot or a troll of some sort.
    IMO for a "bedroom" amp, you can't go wrong in choosing one of Mark Baier's low-power Victoria tweed Fender replicas. There is a complete line of Victoria tweed combos that are suitable for home use, and also as a small club amp.
    If you desire a sensible bedroom amp that won't disturb neighbors, look no further than the Victoria 518 (8-inch speaker), or Victoria 5112 ( 12-inch speaker), faithful Fender tweed Champ replicas. With it's single 6V6-GT power section these amps deliver a sensible output of about 5 watts.
    Here's a link to Victoria Amps:
    http://www.victoriaamp.com
    "Scan not a friend under a microscopic glass; you know his faults so let his foibles pass".
    Sir Frank Crisp
    Friar Park
    London, England
    Quote Originally Posted by vseprosto90211 View Post
    You're probably right.....note the possible nefarious hyper-link this new LPF member cleverly inserted into his post. I would caution others not to click on this link.
    Sir Frank Crisp
    Friar Park
    London, England
    Actually a 50 W amp plays better at low levels than a 20W. You might get a nice fat clean sound a low levels, and use an overdrive when needed. A 20W always needs more loudness to sound decent and not thin. A 18W BB at low volume is not impressive. At full throttle is blows away most high watt amps.
    Quote Originally Posted by Scott64 View Post
    Marshall jcm 900 50 watt into a 4x12 Marshall 1960 cabinet -
    click the "half-power" switch on the back of the head
