    Bent posts on 1974 lpc tune o matic bridge
    Hi, Im having an issue where the tune o matic threading in this lp is bent to the point of breaking. Thing is, the threading goes into the body, and I have no idea how these posts are put in/replaced(dont want to yank anything out without knowing). Its a 1974 gibson les paul custom, and its seen a lot of play. Where would i even begin to replace it, let alone find a replacement in-body post? Ive only used/seen the ones with large installed bushing and thumb wheel and threaded post are the same piece. Thanks for any help. Edit: the posts are .126” wide, .752” out of the body
    https://imgur.com/f4JfPuj
    https://imgur.com/WJkrTRi
    https://imgur.com/XC54fhR
    Re: Bent posts on 1974 lpc tune o matic bridge
    They are just simple threaded rods measuring 1 and 1/16" of an inch long by 1/8" thick with a 6/32 sae thread size.
    SAE is an American thread and not metric. These are available almost everywhere online or at a music shop. There's no
    harm in unscrewing them from the body whatsoever.
    if you can’t unscrew them by hand put two nuts on one post and use the bottom one to back it out using a wrench ..then there’s a good chance that you can bend it back straight ..I’d try a using a vice with one post placed inside two blocks of wood then slowly crank it tight..if it works then do the other
    Les Paul Forum Member guitplayer's Avatar
    Wizzconsin
    I have seen some from 74 with bent posts. Some cut short too.
    If you replace it , its good that the new posts rest alll the way down in the guitar.
    And up a proper height inside the ABR,
    " Never Mind Your Face, just show us your card"
