Results 1 to 10 of 10
Thread: National 6422TR
    Les Paul Forum Member kwest's Avatar
    Feb 2007
    National 6422TR
    I found this amp in my girlfriend's basement. She said it doesn't work but actually it just needs a new reverb tank. The old one is made of cardboard which is falling apart.
    Feb 2007
    Re: National 6422TR
    This is a video of the same model amp.
    Les Paul Forum Member fernieite's Avatar
    Jan 2010
    Toronto
    Re: National 6422TR
    Wow, great find! I hope its easy to get it back up and running.
    Feb 2007
    Re: National 6422TR
    Quote Originally Posted by fernieite View Post
    Les Paul Forum Member MapleFlame's Avatar
    Somewhere between Woodstock and NOVA
    Re: National 6422TR
    Great sounding amp. I love the lower wattage amps, great to gig with, just mic them in front and back. No pedals needed for overdrive.
    Top carves are sexy
    Les Paul Forum Member Wood Spanker's Avatar
    Dec 2019
    Oregon Coast
    Re: National 6422TR
    Too cool! The amp in that video sounds great! I wonder what else might be lurking in the basement?
    Feb 2007
    Re: National 6422TR
    Quote Originally Posted by Wood Spanker View Post
    There was an Akai AX-80 Synth down there. But that doesn't work either
    Re: National 6422TR
    If the amp hasn't been used for a significant period of time you should be wary about powering it up, the filter capacitors will likely need to be re-formed or replaced and powering it up without doing this first could cause further damage (the fusing on some older amps can sometimes leave something to be desired so you shouldn't automatically assume the fuse will protect it in the event of leaky or shorted filter caps!).
    Feb 2007
    Re: National 6422TR
    Thanks! Got my amp back. Swapped out the old reverb tank and original power cord and replaced one pot.Sounds great now!
    Feb 2007
    Re: National 6422TR
    Now I am just waiting for my Les Paul to arrive.
