    Mini Switches like Regular 3-way toggles?
    Anyone know if there is such a switch? I want to replace the mini on my ‘65 Epiphone Al Caiola that only is a two way. It only lets me switch between neck and bridge, but I’d like to have neck- both and bridge.
    Re: Mini Switches like Regular 3-way toggles?
    The type of switch you need is a DP3T ON-ON-ON switch. I believe your Epiphone has slide switches? In which case something like this may be what you need https://www.mouser.co.uk/ProductDetail/Conxall-Switchcraft/46313LDRX?qs=HevK2UT75zv24tJpsDjQXg%3D%3D&vip=1&gclid=EAIaIQobChMI1Yr7qN2O5QIVTLDtCh2zwQtwEAYYASAB EgKNWPD_BwE but you would need to check the physical size to see if it would fit.
    Thanks! I have an account with Mouser. They’re always real helpful with sizes, etc
