Results 1 to 28 of 28
    Any Jazzmaster fans?
    I’d love to see yours. Especially any thinline JM’s as that will likely be my next project. I’m collecting color/pickguard ideas for future use. It will be a thinline partscaster if I could find a good thinline body.
    I have two CS Jazzmasters that I adore, tone, playability and ergonomics. The Shell Pink Wildwood 10 is 7.93lbs, and the Vintage White Closet Classic is 8.03 lbs.
    The Closet Classic has the traditional/typical low neck angle and it does tend to need the heavier gauge strings to cure bridge rattling/buzzing. Even if the bridge saddles or other parts don’t rattle much, if the break angle across the saddles is not high enough you will have the low E, maybe others, buzz in the saddle. I shimmed it with a 0.5deg Stew Mac shim and no buzzes whatsoever with a Staytrem bridge (not available anymore but you can look at the Johnny Marr bridge and the American JM Pro bridge, or a Mastery bridge…I think the latest AVRI bridge may be good to go too), and with Thomastik flat wound strings, which I’ve tried both 12gauge and 10 gauge, again with no buzzing whatsoever. I have put 10-50 round wound strings on it, from a 10 gauge NYXL top and a 11-50 NYXL balanced tension bottom, and the low E buzzed in the saddle . But after I properly stretched the string including across the saddle, and the string stabilized, no buzz, and I think I’ve found my perfect JM string gauge set up.
    The Wildwood 10 JM has the RSD bridge, which is pretty impressive. Extremely solid and stable, and I think it gives the guitar great sustain and punchy twang, and yet the guitar retains JM shimmer and jangle. This guitar has a neck pocket that gives the same neck angle, or thereabouts, like the Closet Classic WITH the shim in. This guitar has no buzzes/rattles strung up with 10-50 round wounds, and if the relief is pretty flat allowing you to raise the bridge higher, even 10-46 is totally doable. But again I love the feel and tonality of the 10-50 set.
    So Jazzmasters can have issues but most are totally resolved by keeping a nice flat neck relief, and/or adding a shim. The payoff is huge in my opinion however if they are dialed in right.
    Forgive the sloppy pedal board but I’m in the middle of rebuilding it.
    As a bonus, for Greg Koch fans, here he is playing the Shell Pink one before I bought it, right after he plays an awesome Strat.
    https://www.facebook.com/wildwoodgui...epa=SEARCH_BOX
    Re: Any Jazzmaster fans?
    That looks like it might be a Fender.
    HŁter der Flammen!
    Should have I posted that in the Fender forum? But lots of people can have PartsMasters too, which would not be Fenders. But yeah it's obvious that mine are Fenders so thanks for moving it!
    Les Paul Forum Member Ed Driscoll's Avatar
    South of Dallas
    Not really my thing, But I did like the Mondrian-esque paint scheme on Adrian Belew's mid-'80s-era Kahler and Roland synth pickup-equipped Jazzmaster:
    Update: 30 seconds after posting this, I just discovered that it's a Fender Mustang. Oh well, close enough for Fender work.
    Les Paul Forum Member zhivago's Avatar
    Sep 2004
    London, UK
    I love Jazzmasters...aside from Les Pauls and ES thinlines they are my favourite electrics.
    Mine's from 1961...
    for all things Jazzmaster, check out www.offsetguitars.com
    Guitars: '56 Les Paul Custom, '63 SG/LP Custom, '61 Jazzmaster, '43 000-28, '15 ES-345,
    Amps: Matchless Lightning, Zvex Nano amp
    Pedals: Centaur, BJFE, Analogman, Zvex, Maxon, etc.
    Les Paul Forum Member fakejake's Avatar
    Sep 2010
    lost in the changes
    I just recently got this refinished '64 JM. Really great guitar. Light, big neck, strong pickups.
    I dind't care fro the trem so I put a fixed tailpiece on. That really changed the feel of the guitar.
    Quote Originally Posted by RocknRollShakeUp View Post
    I didn't move it [I can't]. But I think you'll find more Jazzmaster fans here.
    HŁter der Flammen!
    What bridge is on that pink one? Doesn't look like a StayTrem...or not at least the ones I've seen?
    I love JM's when they're "right". Here's my '63. Massive sound. Puts a smile on my face everytime I use it live.
    Les Paul Forum Member Hot_Snake's Avatar
    Sep 2010
    France
    '63 Jazz here
    bridge is now replaced by a Mastery ...
    Hot_Snake, I think your 63 has played fewer gigs than mine! What a beauty!
    Quote Originally Posted by Ed Driscoll View Post
    Yeah I was trying to figure out what that was! Well it is an offset body so yeah close enough! But very cool 80ís art work.
    Quote Originally Posted by zhivago View Post
    Mine's from 1961...
    What a beauty! I have to say black with tort guard is Super bad ass! How are the neck dimensions on it?
    I do sometimes post on offsetguitars.com.
    Quote Originally Posted by fakejake View Post
    Sounds fab. Picture didnít come through, please try to repost. Iím intrigued about the fixed tailpiece, although I love the Jazzmaster trem!
    Oh man Iím all sorts of confused I guess :D
    Well people can have like a Danocaster, or other boutique JM, or PartsMasters, so I guess itís OK where it is. But yeah, good point.
    Quote Originally Posted by latestarter View Post
    Damn, another beauty! I love it.
    That bridge is an RSD bridge, exclusive to the CS JMís as of more recently. Superb bridge and Iíve tried most of them. Canít buy it aftermarket though. The vintage white one is a Staytrem!
    Quote Originally Posted by Hot_Snake View Post
    '63 Jazz here
    Gorgeous..ok so instead of having a thinline JM built I may ought to think about a vintage one!
    How do you like the Mastery? Did the stock bridge give you issues?
    (Stupid F*ing Photobucket.)
    Early '60 Blonde.
    Refret in the mid 90's, otherwise she's all stock.
    Was my main guitar for most of the 90's. Now my happy house guitar.
    Sep 2004
    London, UK
    Hey thanks!
    The neck feels a bit chunkier than other vintage JMs I've played...I've never measured it properly as I have no callipers.
    It's a very playable neck all around...I re-fretted it a few years ago and it just plays effortlessly
    Sep 2010
    lost in the changes
    Trying again...somehow it seems I have trouple posting pic from my google account...
    [IMG][/IMG]
    Sep 2010
    France
    Mastery Bridge is a killer add on to a Jazzmaster.
    The original one was as long as you didn't use the tremolo.
    Mastery doesn't move in the post, intonation is spot on, strings don't move, tremolo is a pleasure to use, even with light string gauges.
    Can't say enough good things about it.
    Quote Originally Posted by sonar View Post
    Early '60 Blonde.
    Too cool for school..love it.
    [IMG][/IMG]
    Very nice! Oh yeah Iíve seen those hardtail plates before. Good option to have. If anything though when I have an issue with a JM it is the bridge and not the Trem, although I did have one break down the end wrap of my high E strings all the time until I got some abrasive floss and smoothed out the string holes!
    Sounds good Iím glad itís working out well. Iíve had great results luck with the Staytrem and with that RSD bridge. Iíve tried them all pretty much in various guitars and the Mastery is still on my good list for sure too.
    it's nice to have these options. I used a buzz stop for a number of years and hated it.
    Indeed. Yeah I totally agree buzz stops are not the right answer.
    What`s a fair price for a `66 Jazzmaster;
    Transition model, dot inlays and binding. Original pu`s, replaced pots.
    Les Paul Forum Member J T's Avatar
    Oct 2005
    NYC
    Yes I had that Wizzo on but took it off because the strings went off the bridge at such a sharp angle they contacted the back of the bridge. I now have a Mastery bridge and trem and they are great. Highly recommend the Mastery bridge.
    The farther you go, the closer you are.
    Quote Originally Posted by J T View Post
    Thanks for the recommendation. My guitar is all but retired to a life of leisure and the occasional recording session, so it’s not a priority. If I ever start taking it out of the house I’ll grab a Mastery.
