Results 1 to 40 of 62
    Formerly Lefty Elmo Steve Craw's Avatar
    Sep 2004
    Upstate NY
    Incoming!!! New Vintage Guitar Day!!!
    Just finalized the purchase of this stunning left handed 1964 ES-345. Thanks Alex from Lefty Vintage Guitars. It should be here in a few days, the waiting is the hardest part!
    Re: Incoming!!! New Vintage Guitar Day!!!
    Nice one Steve!
    Congrats, Steve!
    Totally awesome! Congrats.
    Please reassure me they didn't appoint it as a lefty then drill the ABR for a righty?
    Looks gorgeous nonetheless.
    Les Paul Forum Member corpse's Avatar
    Dennis, MA
    Great score Steve.
    Right-handed inlays on a left-handed guitar. So wrong but so very, very right! Awesome!
    Post a tone & play-ability report when you can!
    Les Paul Forum Member Jim W's Avatar
    Chicagoland
    Congrats! Looks awesome!
    It's upside down and backwards!
    Les Paul Forum Member wmachine's Avatar
    Mar 2016
    Ohio
    Nice! Good to see you lefties get some good models.
    A '64 reissue, I take it? I'm guessing a late model Memphis special order?
    "I am the kind of guy that only buys 100 watt heads just to play at home. I feel like if an amp can't kill a heard of cattle 100 yards away what is the point of owning it."
    Quote Originally Posted by wmachine View Post
    Real deal... albeit rare. Clean machine!
    Mar 2016
    Ohio
    Quote Originally Posted by jb_abides View Post
    I presume you mean an original '64? Those reissues are the "real deal" too, trust me!
    It looks like the label inside is the same as used on the reissues. But apparently the labels look the same as the originals, too?
    An original lefty must be extremely rare? What's the history on them? I don't see many '64 345s period!
    Yes, original to '64 not reissue. Here's detail from Alex if you are interested... Maybe Alex will chime in some point to elaborate.
    http://www.leftyvintageguitars.com/1...ely-rare-lefty
    1964 Gibson ES-345TDC, Cherry Red, Extremely Rare Lefty!
    This is a Left Handed 1964 Gibson ES-345TDC. I have only seen 4 other Left Handed Golden Era(pre-1965) ES-345s: 2 from 1960(I currently own one), 1961, and 1962(which I previously owned). I have not seen any from 1964 – this is probably the only left handed 1964 ES-345.
    The original owner had his name inlayed into the original fretboard, which was replaced with an Ebony board at that time. Recently, the guitar was shipped to Lay’s Guitar Shop and the fretboard was replaced with a historically-correct Brazilian Rosewood fingerboard with Double Parallelogram inlays(receipt from Lay’s included in the case). The fingerboard binding and nut were also replaced at the same time. There are side dot markers on both sides, which is historically correct for a vintage left handed Gibson. Lay’s also did a refret and complete setup – the guitar feels and plays great. Dan Shinn does great work at Lay’s!
    In addition, the following parts have been replaced; Varitone switch, position indicator plate and control knob, choke coils, tuners, truss-rod cover. Most of the wiring harness has been replaced with cloth-covered Fender-style leads, the selector switch has been re-wired, the cans have been removed, heat shrink has been added on the pickup output leads, the bridge ground lead has been cut from the bridge pickup output lead and re-soldered in a different location on that lead. The bridge is currently oriented for right-handed compensation, leaving visible fill and finish touch-up at the original left-handed locations of the mounting studs, the neck position pickup cover has previously been removed and subsequently re-installed and the position of the pickup magnet has been reversed. There is visible finish overspray on the neck rear and around the fingerboard extension.
    Overall, the original finish shows typical deterioration with lacquer checking, small dings, compression marks and edge-chipping (peghead). The metal hardware displays gold-plating loss due to friction rubbing. In other respects, this instrument conforms to the typical specifications of the model for the period in which it was made with double cutaway thinline semi-hollow archtop left-handed body, F-holes, laminated maple top, back, and sides, cherry red finish, elevated multi-ply beveled-edge black plastic left-handed pickguard, two humbucking pickups (both “patent #”) with metal covers and black plastic mounting rings, tune-o-matic bridge with metal string saddles, Maestro vibrato tailpiece with embossed lyre & logo, Varitone switch with gold-colored indicator ring, four black “reflector cap” control knobs, toggle-type pickup selector switch, mahogany neck with adjustable truss-rod, classic “open-book” shape peghead, pearloid Gibson logo and “crown” peghead inlays, multi-ply white & black binding on body top edge, single-ply white binding on body rear edges, and gold-plated metal hardware. The instrument is currently housed in a replacement (Harptone) hard-shell case with black Tolex exterior covering and burgundy plush interior lining.
    So while the guitar has changed parts and modifications, it is a factory Left Handed 1964 Gibson ES-345, probably the only one. And it is one of a total of only 5 Left Handed Golden Era Gibson ES-345s known to exist. The guitar has a great look – the ES-345 is the coolest looking ES model IMO. And if you play the Blues, a Cherry ES-345 was the guitar of choice of the great Freddie King. This is an opportunity to own an extremely rare Left handed 1964 Gibson ES-345 at significant savings!
    Steve - looking forward to your report, as I am sure you are looking forward to getting it in your hands. And if you stop in to HoG please apprise of any lefty sightings
    Sep 2004
    Upstate NY
    Quote Originally Posted by deytookerjaabs View Post
    No they didn't. The bridge was relocated for a lefty player who strung the guitar with the bass strings on the bottom. I'll re-set the bridge back to the original location after I get the guitar. Good eye!
    Sep 2004
    Upstate NY
    Thanks all ! It's getting shipped tomorrow, so it won't be long (it'll just seem like it)
    "The original owner had his name inlayed into the original fretboard, which was replaced with an Ebony board at that time. Recently, the guitar was shipped to Lay’s Guitar Shop and the fretboard was replaced with a historically-correct Brazilian Rosewood fingerboard..."
    Can you get the original fretboard? That would be awesome.
    That is so sweet, I don't have words!
    Mar 2016
    Ohio
    Quite interesting, thanks. Extremely cool piece of history. And a very cool model, even lefty aside.
    This is the *exact* model that was a reissue in 2016, the "Gibson ES-345 TDC 1964 Maestro VOS Sixties Cherry". I was excited to be able to get one, supposedly one of 60 made for worldwide distribution.
    So it really is a thrill for me to see an original! What a story to follow!!
    Sep 2004
    Upstate NY
    What a beauty! I wish Gibson would have made a lefty reissue of these. But I'm going to be VERY happy to have an original.
    Sep 2004
    Upstate NY
    Quote Originally Posted by brandtkronholm View Post
    Thanks for asking this question. It inspired me to ask Alex that question. He asked Lays, and it seems that they still have the board, so hopefully I'll be able to get my hands on it.
    Quote Originally Posted by Steve Craw View Post
    Post this pic when/if you can get it. (New wall hanging!)
    That'd be very very cool!
    Les Paul Forum Member Mars Hall's Avatar
    Nov 2008
    The Region
    I'm drooling over here!
    "What's that man movin' cross the stage?
    It looks a lot like the one used by Jimmy Page..." Paul McCartney
    Sep 2004
    Upstate NY
    Thanks, me too! Wednesday can't come soon enough. Funny thing, the tracking says it's near Syracuse, which is less than 90 minutes away, so...... maybe it'll show up tomorrow.
    Administrator MikeSlub's Avatar
    America the Beautiful
    Killer score Steve!
    Mike Slubowski
    * "Gibson guitars are like potato chips - you can't have just one!"
    * "So many Gibsons to love, so little time..."
    Les Paul Forum Member TomGuitar's Avatar
    Apr 2005
    Ann Arbor, MI
    Very cool. Those have to be almost impossible to find. Beautiful guitar, Steve.
    Sep 2004
    Upstate NY
    Update: She's arrived a day early, and I'll be picking it up today!
    Les Paul Forum Member Shocktop99's Avatar
    Mar 2017
    Somewhere between Here and There
    I Love this!! Happy NGD! Enjoy that beast of a guitar!!!
    1979 Wine Red Gibson Les Paul Custom
    2019 Mills Custom Amp Atlas 50 Watt
    1974 Gray Les Paul Custom
    2020 Pelham Blue SG
    1984 Roland Jazz Chorus 120
    2019 Fender Hot Rod Deluxe George Benson Signature
    2019 2x12OG Emperor Cab
    1983 Fender Stratocaster Elite
    "When you plug it in... when it gets electric, its just a complete different world."
    -Adam Jones Circa 1994
    "Live wrong and Perspire"
    -Anonymous
    Sep 2004
    Upstate NY
    Well, she arrived in perfect shape, Alex did a great job packing her. I haven't decided what I'm going to do about re-wiring yet. The Varitone is sort of cool, but the pots are wired lefty (which I've never liked) plus the issue of stereo to deal with. It's a warm sounding guitar, and I'm looking to rehearsal tonight do drive it a little harder
    ...the issue of stereo to deal with...
    Here's the solution for stereo Gibsons!
    I received my ES-Box built by BMF Effects last week.
    This is THE solution to the complications of using a stereo guitar with a single input amp. It's as easy as pie to use. You may keep your ES-345s, ES-355s, or any other stereo guitar fully original and use the same amp that you use with your Les Paul, ES-335 etc. In fact, switching from Stereo to mono guitars is effortless.
    The box is small, heavy and very sturdy! It has a battery/DC but also works perfectly well passively if you run out of battery power!
    I encourage everyone with a stereo Gibson to give this box a whirl! The price is ~$180.
    Again, this is THE solution.
    Here's the picture of the box and some additional info posted by deytookerjaabs earlier in this same thread.
    It was explained to me that it "fools the guitar into thinking the signal is stereo" so you don't get certain bits of frequency summing/cancelling. Scott can explain it better than I if you shoot him an email, nice guy, quick shipping, great service, etc. I've used it again the past few days and oh I'm so glad I bought it, haha. The mono/stereo switch is for if you're plugging in the stereo guitar with TRS cable then if you want to switch to a regular guitar you can.
    Link to thread: https://www.lespaulforum.com/forum/s...solution/page2
    Sep 2004
    Upstate NY
    So, as an experiment, I bought a stereo "Y" cable. I plugged into the two channels of my Deluxe Reverb, and found that the stereo is actually VERY cool. Using the EQ'ing of the separate channels, I can custom tailor each pickup, rather than trying to get a compromised sound from one set of tone controls that are set to try and sound good on both pickups. I'm sold ! I will not be re-wiring this guitar anytime soon.
    You can try plugging the stereo-Y cable into one channel and experiencing the funk of the out of phase sound - see reverb channel of the Fender below. (Out of phase should always be said as if it were "Pigs in Space!" from the Muppets.)
    Just wiggle a volume knob a tiny bit to reduce the "out of phase!" sound. I'll hook up two wah pedals with the stereo-Y. Put one wah all the way back and roll the corresponding tone knob all the way back for an extreme version of 'woman tone.' What fun!
    Jun 2019
    Beautiful and exciting to see. That guitar wears its age beautifully. I hope you get the fretboard. I am surprised that the shop did not include it automatically. I know there's no law requiring all parts to stay with the original guitar, but that should be the custom, particularly at this level of sale. Congratulations on a really fabulous guitar.
    Forum Moderator T.Allen's Avatar
    Sep 2014
    Ohio
    Congrats Steve! That is a beauty!
    Sep 2004
    Upstate NY
    Quote Originally Posted by one View Post
    Lay's has it and will shipping it to me this week.
    Sep 2004
    Upstate NY
    Lays still had the fingerboard, and sent it to me!
    Suitable for framing!
    This
    Is
    Awesome
    ...also, are those bass frets? They look enormous!
    Fretboard visible in video montage here -
    Courtesy of -
    http://www.stlmusicyesterdays.com/Unknown.htm
    Sep 2004
    Upstate NY
    Holy crap, JB!! Thanks for finding that! I had googled and come up empty.
    No problem, Steve. Now you have some provenance, to become keeper of a legacy.
    Cool band... it seems. Maybe they're more known than "Unknown" now at least to me.
    I particularly liked their Byrds cover. Ah, what a great Gene tune!
