Results 1 to 12 of 12
    1960 Gibson Melody Maker
    I have a 1960 MM that I would like to get a different bridge. For some reason mine has the lightning bolt compensation wrap around, but it's a 1960, with the offset angled posts. I would like to get a new wrap around with adjustable compensation to tweak the intonation. Would I have to also replace the posts? Or can I use the originals with most replacement bridges? I dont want to do any drilling. Thanks
    Re: 1960 Gibson Melody Maker
    https://www.ebay.com/itm/Wraparound-...ss!21078!US!-1
    you should be fine using the original studs with this one.
    Les Paul Forum Member guitplayer's Avatar
    Wizzconsin
    If I played alot high up on the neck, I`d use this.https://www.stewmac.com/Hardware_and...waAkrKEALw_wcB
    " Never Mind Your Face, just show us your card"
    I use locking studs like this so the bridge doesn't sit at a funky angle making for a poorer string break: https://reverb.com/item/1272687-lock...ith-us-threads
    plus a compensated wraparound. It's crazy Gibson still makes the tolerances so loose the bridges sit off kilter in the studs.
    Quote Originally Posted by garywright View Post
    That price seems quite reasonable... Is there much difference in tone and/ or quality compared to pigtail, or other replacements for this bridge? The others seem to be in that $80-100 zone. Thanks for help!
    Quote Originally Posted by deytookerjaabs View Post
    Yep I hear ya! My bridge is a compensated lighting bolt (old style) for parallel posts, but I have offset posts, so I have the grub screw screwed way in on bottom post to help lengthen the strings to get the intonation better. But with the offset posts and a lightning bolt, I'm not getting the right kinda relief lol. Might need to try the locking studs u suggested, thanks
    This is what I have on my `60 Melody Maker and on my `59 L.P. Special:
    https://abm-guitarpartsshop.com/ABM-...ckel::433.html
    Best thing I did for either of them!
    There are two types of studs for TP's, vintage spec and modern spec. Modern fits the thicker ears on zinc tailpieces, vintage spec fits the thinner ears on vintage lightweight tailpieces. The problem with Gibson is they are putting vintage spec lightweight TP's with the thinner ears on modern studs, so the TP's lean in between the stud flanges. Just replacing the studs with vintage spec (either steel or plated brass) studs should fix the problem. Gotoh sells them, I think in plated brass, I have RS Steel studs that a vintage type TP fits tightly into, and also they fit tighter into the bushings in the body.
    Al
    Quote Originally Posted by zombiwoof View Post
    Al
    Yeah, I've never measured it but I can say that my vintage studs with the original compensate for wound G piece still lean and the piece with the studs on my 2017 'bird do the same damn thing and lean! I also had a junior from a few years back...still leaned! What do they say? "Boy, that's not a mistake, that's a feature."
    All my original wraptail tailpieces fit tight to their original studs. They don't wobble or slant. I have 6 singlecut Melody Makers with original hardware and the bridges stay put even minus strings.
    So many had Badasses installed in 70's, which used large flanged studs I suspect when swapped back to stock bar bridge many used modern studs. Right stud = tight fit. I always get the proper fit new stud bolts to fit any new or alternate bridge and lable and package the original bridge AND stud bolts together for storage.
    Jan 2019
    Quote Originally Posted by Masterworks View Post
    schaller made a stoptail with adjustable saddles. gold and silver, its pretty chunky but worked well on one of my juniors.
    i love melody makers! i have stock ones but really like the grover/badass/humbucker ones that were put together, and they were dirt cheap in the nineties. nice lightweight guitars.
    Quote Originally Posted by agogetr View Post
    I believe that's the Schaller 455, I put one on my Brother's Melody Maker years ago when I was gigging with it and it was a great bridge. It's like a tunematic/TP in one, the TP part slides into the back of the adjustable saddle bridge part. They have another variation where the back TP part had fine-tuners on it, never tried that one. They are pretty heavy but sustain well.
    Al
