Thread: Tone Control
    Tone Control
    Hope someone can help. Bought the new les Paul special tribute with p90s. The tone control seems non existent until i turn it to two or so and then I get the full effect of the treble cut. Is there a way to get more usability out of it? Maybe changing the pot or cap?
    Re: Tone Control
    I don’t know what pot values and tapers Gibson uses in that model, so I can’t tell you what small mod would fix this. But for sure, if you removed everything in the control cavity, and then replaced it all with a good 50’s wiring control harness made up of CTS 500k audio pots, and .022uF caps (orange drops, Mallory, or any other quality cap type), you should have controls that are nice and responsive. It might be the brute force approach, but it will work.
    Re: Tone Control
    Quote Originally Posted by Krank View Post
    Sounds like the tone pot has the wrong taper. A good tech should be able to correct this by getting the correct pot.
