Thread: switch nut
    london uk
    switch nut
    what would be the correct tool to tighten the switch nut without damaage
    Re: switch nut
    Quote Originally Posted by Del View Post
    I have a piece of leather that the rough side has quite a long "pile"....I just use my fingers with that over the nut and grip it hard. The leather grips the nut, job done. I have used needle nosed pliers with tape around the nose. The leather works better for me.
    Then there's this.
    https://www.lespaulforum.com/forum/s...witch-nut-tool
    Re: switch nut
    I use my fingers. Can’t over tighten it which can cause the pocket chip to crack. I really like the leather suggestion though. I plan to try it.
    Hong Kong
    Re: switch nut
    There is a StewMac adjustable tool that I regularly use to loosen switch nuts which have become immovable from
    sweat/grime/years of play.
    When used properly, you'll never have to worry about those pliers getting away from you & messing up the top.
    For tightening the nut, I like leather..........
