Results 1 to 16 of 16
Thread: The Ox box
    Les Paul Forum Member Xpensive Wino's Avatar
    Nov 2012
    In the pocket
    The Ox box
    Nov 2012
    In the pocket
    The Ox box rocks
    Les Paul Forum Member Pellman73's Avatar
    Aug 2016
    Pinehurst, NC
    Re: The Ox box
    yup. I think they look awesome!
    I ordered one a month ago... they are hard to find.... about two or three month wait
    I've got a rivera Rockcrusher recording that is like the less evolved version.... works great but I think this will be a step up
    as Ren said I do think they copied some of the stuff from the Two Notes deal but .... given that its UA you gotta think its good.
    Aug 2016
    Pinehurst, NC
    Re: The Ox box
    Ok I got mine and its absolutely incredible.
    straight out of the box its just amazing
    sounds amazing as an attenuator but shut that down and the line out into my computer sounds just as amazing
    each setting is basically a soup to nuts thing with effects, the cab simulation, the mic position, compression ... whatever-- the end result sounds like the best sounding studio recorded guitar sounds ever to come out of your rig.
    lots of built in effects for each room setting-- all the presets just sound incredible.
    this thing is like CHEATING it sounds so good.
    I believe this is a revolutionary device.
    Nov 2012
    In the pocket
    Re: The Ox box
    All Access/Backstage Pass Progrocker111's Avatar
    Dec 2003
    small country full of nice women and good beer
    Re: The Ox box
    Wow, great tones and playing. Perhaps this is really the right one attenuator, which i need for my Hiwatt DR103.
    My diagnosis is: Hiwatt and Norlinphilia
    1977 Gibson Les Paul Custom winered
    1972 Hiwatt DR103, 1972 Hiwatt SE4122
    Aug 2016
    Pinehurst, NC
    Re: The Ox box
    Quote Originally Posted by Progrocker111 View Post
    wino is that you ??
    Progrocker keep in mind, if we are going to talk semantics here, that that recording is likely from the OUT of the box into that Apollo thingie so its really more the OX box doing its direct to the DAW thing
    the Attenuator part of the OX box does not give you all the luscious OX box magic with the cab/mic/room/effects simulation that you get from the line out
    it is just the sound of your amp attenuated. Now-- it is a GREAT attenutator-- better than my rivera rockcrusher but what it does with the line out (which can be a digital line or a regular quarter inch instrument out) is really whats magical
    you dig?
    Les Paul Forum Member jam81's Avatar
    May 2016
    Chicago
    Re: The Ox box
    I have one and I love it!
    The only issue I have is with the attenuator when using my amp's clean channel, if I turn the volume up on my amp it distorts the signal on levels 1 & 2 of the attenuator, it does not happen on 3 4 & 5. I am not sure if this is the attenuator or the amp's fault, I am getting my other amp back from the shop this weekend so I will test it.
    Aug 2016
    Pinehurst, NC
    Re: The Ox box
    So I made this little video so you all could really hear just 6 of the rigs (these are the 6 stock rigs that it starts out with but you can put whatever you want in as the "6" for the front knob.
    All the effects you hear are the box
    Matchless HC-30 with jsut OE cali 76 compression and a Centura set with gain way down and output up-- no effects
    you can hear big room tones and small room tones-- these are all based off the cab simulation, room simulation, and the built in effects
    I'm sure I could do better with the metering but this is direct from the box into my computer and just recording in the photobooth
    I wish I could play better but at least you could hear the tones and I tried to do roughly the same riff 6 times both for rhythm and "cough" lead
    Dec 2003
    Re: The Ox box
    Wow, thank you very much.
    Great to hear all the effects
    Nov 2012
    In the pocket
    The Ox box rocks
    Dec 2003
    Re: The Ox box
    Really great tones
    Re: The Ox box
    Drips wit 'em!
    Les Paul Forum Member J T's Avatar
    Oct 2005
    NYC
    Re: The Ox box
    Hey guys, anyone still using the UA OX?
    Like to hear what youse guys think a year later.
    This is a high priced thang. But is it worth it?
    The farther you go, the closer you are.
    Les Paul Forum Member Skydogfan81's Avatar
    Dec 2006
    In the mountains by the sea
    Re: The Ox box
    Waiting on the next version. To me, the best use is late night with the only output going into your DAW. Not a big fan of attenuators otherwise.
    Get Something out of Everything!
    Oct 2005
    NYC
    Re: The Ox box
    Cool Thanks. Seems like it's geared more toward recording with all the UA plugs available.
    This is expensive. Could just get a nice amp
