Results 1 to 11 of 11
    I need an education to teach! EMG content
    Hey, I run "The Gundry Guitar Institute" in Orrville Ohio and my lessons contain full discussions on tone, gear and getting it all together. I have a new student who is into metal. I personally have not dipped into that genre of music very deep so my knowledge of EMG pick ups are nonexistent.
    He has presented a problem to me that I would answer out of hand but with active pickups I am a bit lost.
    SO I come to my favorite group of experts for anything musical the LPF!
    It is a simple description. His pickups are squealing so bad that they are unusable. My first reaction was to immediately think in the passive world that they were not potted and needed to be to correct the issue. BUT what about active pickups? Are they all already potted? Is it impossible to do due because of the electronics involved? Is there a common set up solution to address this issue?
    As usual, any and all help is deeply appreciated and I thank you in advance!
    Les Paul Forum Member Hamerfan's Avatar
    Dec 2004
    From the best part of Germany - Bavaria
    Re: I need an education to teach! EMG content
    EMG are quieter in term of idle noise and hum, but are more prone to squeal. EMGs work best with solid state and low gain tube, but have often a problem with high gain tube amps. Sometimes a pedal without buffer cure this overload or plugging into the low input. Its basically a low impedance pickup in a high impedance input, that causes some trouble.
    A slight chance: a low battery status - this creates sometimes weird things in preamps or a microphonic input tube.
    Hope that helps.
    Thank you Hamerfan. You answer goes completely opposite to anything I had assumed or considered. For example, you mention that these do not work well with high gain amplifiers. It is my experience that the majority of players who install EMG's are looking for high gain tone since they seem to be the most popular with heavy metal musicians. I believe my student is plugging into a Marshal. I will ask him about his regular choice of input jack and battery status. Thanks again.
    Dec 2004
    I know that metal is about hi-gain, but e.g. Mesa boogies were made to give hi-gain structure to passive high impedance guitars. If you go to the limits with internal preamps, buffered pedals, selected input tubes,... you get to limits and feedback.
    Squealing is a plague, but controllable with good passive pickups and fine input tubes. Change out some factors like tubes, batteries, cables... and you may find a way to control it.
    Educate him on getting good tone and losing the EMG's
    "So I let the poison go, 'cause baby I always know it'll be there for me"
    Ya' know, that's where I think I am heading with him. The more I teach the more I learn.
    Les Paul Forum Member Grandturk's Avatar
    NYC
    I've never experienced an uncontrolled squeel condition in any active EMG pickups I've ever used, high gain amp or not, nor have I heard this to be typical of active EMGs that are in good condition and wired correctly.
    First - what EMG pickups is he using? EMG makes more than active pickups.
    Second - are they installed correctly or was the wiring done by a 12 year old?
    Les Paul Forum Member Ryan Givhan's Avatar
    Apr 2009
    Lexington Kentucky
    only people i know that use EMG's use very high gain tube amps and they dont squeal . . . unless they want them to with a sick drop tuned pinched harmonic! \m/
    Les Paul Forum Member Pat Boyack's Avatar
    Oct 2011
    The Palace of the King
    Not to be a smart ass but back in the day we used the volume knob on the guitar. When we were not playing the volume was off and vice versa. Many rock guitar players do this.
    Les Paul Forum Member Dave P's Avatar
    Bob Mayo on keyboards. Bob Mayo!
    Are they the open coil EMG's? The enclosed EMG's are sealed in epoxy so nothing can be done internally to those as far as potting.
    Les Paul Forum Founder
    “It is only through inner peace that we can have true outer freedom.” — Sri Chinmoy
    I was about to swap my Seymour Duncan set to EMGs but found this topic and now I have some doubts.
