Results 1 to 14 of 14
    Intonation / Setup
    I just intonated my Les Paul using a Sabine LED tuner.
    I was pretty pleased with the results.
    I am considering getting a Peterson Strobe tuner because most people recommend this tuner for intonation setups.
    Is the Peterson tuner really that much better for setup?
    Which tuner is better, Strobo flip top or Stomp?
    Thanks for the help, you guys are really knowledgeable.
    Les Paul Forum Member ampdan's Avatar
    Feb 2007
    Salem WI.
    Re: Intonation / Setup
    I have the Peterson VS1 strobe and it's the best/most accurate tuner i have used. It's great if you want to use alternate tunings also.
    Oct 2003
    Joliet, IL
    i have the peterson strobo stomp i love it. i haven't used it in terms of a set up yet, but it is great highly recommend it.
    Les Paul Forum Member JXG's Avatar
    Nov 2006
    Newcastle, UK
    I've got a V-SAM, it's excellent for set ups (I'm a luthier) but Ithink it would be overkill for everyday use.
    Phoenix, AZ
    Get yourself a Strobostomp. I have a VS1 that's a permanent fixture on my workbench alongside my Fluke DVOM... and I have a Strobostomp that I take when working on away from my workshop.
    Once you get used to the accuracy of strobe tuners like the Petersons, you'd find it hard to go back to a 'conventional' electronic tuner. At least I did. I have a whole assortment of various Korg and Sabine, etc, tuners that are literally gathering dust on a shelf.
    Rick N.
    "Get to work!" Tommy Emmanuel
    Les Paul Froum Member
    Sep 2004
    If your truss rod & nut aren't set right , the best tuners
    in the world won't help. Then you still can't go by the tuners themselves .
    It's a give and take choice between each string and the other .
    Les Paul Forum Member SabuJSE's Avatar
    Mar 2006
    Hopefully playing a guitar in MA
    The new Stroboflip I can highly recommend. All the diffferent tunings available, the "sweetned tunings", and it's small size let it fit into a guitar case easily. Not to mention, MUCH more exact intonation.
    Next up - replacing my pedalboard tuner with a strobostomp.
    Nov 2006
    Newcastle, UK
    I would worry about the stroboflip, I've broken a few flip design mobile phones dropping them while they're open...
    Feb 2007
    Los Angeles,CA
    Quote Originally Posted by ampdan View Post
    +1
    Les Paul Forum Member TBurst Std's Avatar
    Dec 2003
    OTown
    I love my Strobostomp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Mark
    Guitars: 79 Gibson Les Paul Std, Warmoth S Type, Godin Flat Five X, Duesenberg Starplayer TV, Gretsch White Falcon, Goodall Concert Jumbo, Ovation 12 string, Lakland 55-02 Dlx Ltd
    Rig: Axe-FX II, MFC-101, QSC HPR 112i, JH Audio Pro16s
    Other: High Country hammered dulcimer 17/17/7
    Mar 2006
    The stroboflip is pretty sturdy/substantial and will screw in to a mike stand as well with an included adapter.
    Also, the obvious recommendation is not to drop it ;)
    Les Paul Forum Member BluePat's Avatar
    Calgary, Republic of Alberta
    I recently acquired a VS-1 for $77US on the 'bay, and like others have said, you'll ditch the other tuners real fast when you witness the accuracy of a Peterson. My buddy has a Strobostomp, and I can't believe all that sophisticated engineering can fit into a pedal!
    Keep on pluckin'
    Pat
    Resistance is futile (if < 1ohm)...
    Les Paul Forum Member Doc Sausage's Avatar
    Nov 2006
    Northern Nowhere
    I'm sure this is covered somewhere in this vast forum but is there something about a LP case that when storing the guitar horizontally, causes the (some) strings to be sharp? It never fails.
    Frickengruvin
    I've got the Strobostomp and a vs1. I use use the Strobostomp when playing out, and I use the Vs1 at home. Both are highly recommended and easy to use after you've learned how to use them!
